BIGGER Throttle Body????
Old Aug 10, 2008 | 08:22 PM
BMD18's Avatar
Hi, man i love this site........anyway i was wondering im wanting to buy a bigger throttle body i was wondering what are its benifits and would i need to go with bigger injectors! The size im wanting is a 58mm BBK!!
Bascily im wanting to know what is that going to do for performance wise and would i need bigger injectors because of it??
Thank you!!
Old Aug 10, 2008 | 08:26 PM
BMD18's Avatar
Thank you!!
Old Aug 10, 2008 | 08:31 PM
My Red 93Z-28's Avatar
ZOMG!!!!! j.k.
If you are basically stock, your stock 48mm TB will do just fine. Start with your exhaust system, then move to your intake system (CAI and good filter). These are basic mods that should be done first, then you can get into headwork, cams, upping displacement, bigger TB and injectors, etc. But for now start off with basic stuff that will help you and that you will need to do before the bigger stuff anyway.
Old Aug 10, 2008 | 08:34 PM
shock6906's Avatar
To expand on my post, I have a 58mm throttle body on my car. When I bought it about four years ago, the guy gave me the throttle body. He bought it for the car but never got around to installing it. I ported the intake manifold to match the TB and did the throttle body coolant bypass at the same time. The only reason the car was any faster is because my foot momentarily got heavier. Honestly, there was no real difference before or after. Save your money and do some other mods first if you don't already have the TB.
Old Aug 10, 2008 | 08:57 PM
Green96Z's Avatar
Unless you are running a heads/cam package, you will hardly see any improvement at all. Besides, the intake has to be ported to accept the 58mm blades. Same with injectors. Unless you are running the stockers past 85% duty cycle (which is doubtful on a stock setup) you don't need new ones.
Old Aug 10, 2008 | 09:15 PM
stangitr's Avatar
you don't need that until you start making 450-500+rwhp
Old Aug 10, 2008 | 10:18 PM
If you don't have a cold air intake and a catback, start there, and work your way up to the point where you can benefit from a larger throttle body.
Why did you convert to a non-electronic trans?
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
QuickSilver02
Apr 7, 2015 11:12 AM
