bigger throttle body?
Old May 8, 2005 | 12:09 AM
  #16
fireman's Avatar
Re: bigger throttle body?
I mostly want to upgrade to a 58mm from my 52mm for the snappier throttle response.
With bigger throttle blades/bores, it takes less pedal to allow a given amount of air to flow through, providing a "touchier" gas pedal.
Old May 8, 2005 | 12:12 AM
  #17
tardy007's Avatar
Originally Posted by Tonedef
Originally Posted by Jeremy_30th
I'm going to go with a 58mm Holley but BBK also sells them.
Edelbrock also makes them
Just an FYI, BBK makes the TB for Edelbrock
Old May 8, 2005 | 12:22 AM
  #18
Mindgame's Avatar
If you do a little math, things don't look so good for the stock 48mm throttle body.
Just to give you an example. Let's take a 350 ci motor turning 6500 rpm. We'll assume 85% VE.
350x6500x.85/3456 = 560 cfm
You can calculate air speed (feet/sec) through a given section area pretty easily.
cfm/area x 2.4 or (1/60÷1/144)
Each throttle bore covers half the engine demand so (580/2 = 280)
280/2.81 x 2.4 = 239 fps
General rule of thumb states that anything over 240 fps will cost you power so you might assume we're safe?
What about the throttle shaft?
If the shaft is 5/16" in diameter, then our new section area is 2.22 in^2
280/2.22 x 2.4 = 303 fps
Take the stock LS1 75mm in comparison, calculate area minus the shaft (5/16"??) and you get this
553/5.928 x 2.4 = 224 fps
Not hard to see that you could see some gains in going 52-58 or even monoblade with better heads/cam/exhaust, better VE and higher rpm.
-Mindgame
Old May 8, 2005 | 01:27 AM
  #19
marshall93z's Avatar
-Mindgame
Not trying to nit-pick or anything, but doesn't that equal 290?
Old May 8, 2005 | 01:39 AM
  #20
Mindgame's Avatar
Red face Re: bigger throttle body?
Yep, that's because I had 560 in the head (from our previous equation) and just hit the wrong key.
So it all works out in the end.
Thanks for keeping me on my toes... I went through this pretty quick so feel free to bring any errors to my attention.
-Mindgame
Old May 8, 2005 | 02:00 AM
  #21
Hell, I guess if I would have been paying attention, I would have noticed that!
Old May 8, 2005 | 08:20 AM
  #22
97pontta's Avatar
Originally Posted by Beyonce Knowles
I know there are some "companies" on ebay that will port it out and replace the blades, but I hear alot of people are unhappy with them because the blades stick open and you get a horrible idle.
Some companies may be that way, but not all. I port and sell them on ebay and have had nothing but positive feedback. None of my throttle body blades stick and the blades seal very tightly. I've actually have had a few people trade in their BBK 58mms for a ported 52mm of mine and said that it fixed the sticky throttle and idle problems. There are some companies that don't put sealed roller bearings in and they may have the problems that you stated above.
I just wanted to point out that not all are this way.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
QuickSilver02
Apr 7, 2015 11:12 AM
