bigger injectors ?
Originally posted by 87 LT1 T/A
Need to find a cheap laptop so I can use datamaster. When I really stomp on it the car bogs really bad...... thanks
madwolf has the 233/239 on stock heads (unported)
and the stock injectors couldnt keep up.
here is the thread:
http://web.camaross.com/forums/showt...hreadid=202450
i was told by pcmforless to up the fuel pressure to 58psi with stock injectors and he would change the injector constant to 30lb. and this would be the equilvalent to #30 injector.
my stock fuel pump good not keep up with that, i was leaning out above 5000 rpm. now i have a walbro 255 and all is well.
jesse
here is the thread:
jesse
