bigger injectors ?
Old Dec 29, 2003 | 01:04 AM
87 LT1 T/A's Avatar
bigger injectors ?
Does this setup call for bigger injectors: comp 230/236, ported heads with 2.00x1.56 valves ? thanks
Old Dec 29, 2003 | 01:10 AM
InjectedSS's Avatar
Sounds like a need for some 30's to me... Only way to be sure is install everything then logg the car with datamaster and see where the duty cycle is...
Old Dec 29, 2003 | 01:13 AM
87 LT1 T/A's Avatar
Need to find a cheap laptop so I can use datamaster. When I really stomp on it the car bogs really bad...... thanks
Old Dec 29, 2003 | 01:18 AM
InjectedSS's Avatar
That doesn't mean it's the injectors... Could be something to do with your ignition...
Old Dec 29, 2003 | 01:22 AM
87 LT1 T/A's Avatar
True..... need to recover from x-mas ($) and take my car to the local dyno and see whats up......thanks
Old Dec 29, 2003 | 01:33 AM
QCKZ28's Avatar
madwolf has the 233/239 on stock heads (unported)
and the stock injectors couldnt keep up.
here is the thread:
http://web.camaross.com/forums/showt...hreadid=202450
i was told by pcmforless to up the fuel pressure to 58psi with stock injectors and he would change the injector constant to 30lb. and this would be the equilvalent to #30 injector.
my stock fuel pump good not keep up with that, i was leaning out above 5000 rpm. now i have a walbro 255 and all is well.
jesse
Old Dec 29, 2003 | 01:35 AM
87 LT1 T/A's Avatar
i'll check out that thread....... thanks
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
95craz28
11
Sep 12, 2015 07:47 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
