Big problem but probly easy solution help!
hey i just parked my 94 z28 m6 and smoke started coming out of the engine so i pop up the hood and theres a small hole in the rediator right in between the batery and radiator like in the back (plastic) part on the top. it was spreading coolant everywhere so now i dont know what to do. can this be fixed or do i need a new radiator? plz help i need to get to school tomorrow.
cya
cya
Re: Big problem but probly easy solution help!
Can you post pictures?
Im not exactly sure what may be going on, but if it was me (and not driving the car is not an option) I would try to plug the hole.
I guess more importantly I would be tring to figure out WHY there was a hole.
Another vote for a new radiator if there is a hole in it, doesn't even matter what size the hole is. I've never had to, but I think replacing a radiator shouldn't be hard to do considering it has to be pulled on a cam swap. Look around in the For Sale section, you'll definitely find a used one for a good price.
A radiator shop can fix it or ya can try some two part epoxy if ya can get to it and it's in the plastic tank.Sand it apply the epoxy and let set up.It could get ya by until ya get it fixed.
ChrisFrez
Dec 15, 2014 03:09 PM
ced8
Jul 8, 2002 11:03 AM
