big problem!!!!
Old Feb 16, 2003 | 08:58 PM
1994TransAm's Avatar
Angry MAJOR TRANS PROBLEMS!!! NEED HELP ASAP
Updated problem guys,
okay to fill everyone in... my buddy had a bad u-joint break on him and it destroyed his rear-end and we've been replacing it for a month or so now.... we have everything ready but we couldn't remove the old driveshaft!!!
I used a 5 lb sledge hammer, prybars/wonder bars, air hammer...everything i could think of to remove this thing!!!! BUT NOTHING WORKS
I can rotate the driveshaft and i can push it in 1/2 and inch. but i can't get it out.
with the rear end in place ...the end of the drive shaft is like 1.75 inches away from seating in the rear end yoke !!!WOW!!!!
so i think that his drive shaft has not only slid forward into his drive shaft but has also fussed to the spline of the output shaft!!!
how do i get this off, and how to i fix the possibly bad spline!!!
its a 94z with a TCI streetfighter trans!!!
Old Feb 16, 2003 | 09:51 PM
RamAir95TA's Avatar
If its broken and wrapped up, just cut it out?
Old Feb 16, 2003 | 10:13 PM
89irocz23's Avatar
sawzaw is your friend
Old Feb 17, 2003 | 09:03 AM
i donno about my saws all!!!!!
like i can get to the DS, but i can't pull it out....i can push it in, but nothing happens?
should i break the front u joint and work on the yoke without the DS?
i can't figure how to get this out...i've removed mine 2 times before this....his is just sooo difficult @!#$#@#
Old Feb 17, 2003 | 09:08 AM
drop top steve's Avatar
Get a bigger hammer.
Old Feb 19, 2003 | 06:31 PM
Old Feb 19, 2003 | 06:46 PM
Not sure what your update was , but it sounds like the front yoke or output shaft has twisted splines. Use a come-along to pull the DS and then asses the damage. Probably a twisted output shaft.
Old Feb 19, 2003 | 07:36 PM
I tend to agree with shoebox, sounds like a twisted spline on the output shaft.
Old Feb 19, 2003 | 10:48 PM
how do i get the out put shaft out?
Old Feb 19, 2003 | 11:10 PM
Z28ROC's Avatar
I like the the come-a-long idea. Get it out and see what you're dealing with. Hopefully the splines on the driveshaft are twisted. and there is no damage to the tranny. Then see if a new driveshaft will go in.
Old Feb 19, 2003 | 11:33 PM
Some transmission disassembly required. The method will depend on what tranny it is.
ChrisFrez
Mar 22, 2015 07:00 PM
MadMav
Feb 6, 2015 11:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ChrisFrez
Nov 30, 2014 08:41 AM
ced8
Jul 8, 2002 11:03 AM
