Best way to take out exhaust manilfold
Old May 16, 2011 | 08:43 PM
GMC5.3's Avatar
Cut me some slack if its a stupid question but does the exhaust manifold come out from the top, im trying to take them to get to the head bolts and im having a really hard time with the driver side which is the easier side
Old May 16, 2011 | 10:20 PM
rv93's Avatar
Re: Best way to take out exhaust manilfold
i would assume they come out from the bottom. might be easiest to unbolt them from the top, then go under and take them out
Old May 16, 2011 | 10:26 PM
ACE1252's Avatar
If you are asking about the LT1 in a Camaro, I've pulled them out the top and bottom.
Old May 17, 2011 | 06:35 AM
1994formy's Avatar
Remove #3 and #5 spark plugs, pull out the top..... Remove dipstick tube for passenger side.
Old May 17, 2011 | 07:40 AM
gcouse7's Avatar
drop the motor out.
Old May 17, 2011 | 09:42 AM
TD95Z's Avatar
Remove the spark plugs and it will come out the bottom. The problem we ran into when trying to take them out the top is that the three-bolt flange got stuck between the block and the steering shaft. I ended up unbolting the shaft afterwards since we're doing longtubes, so I may have been able to come out the top with it.
Old May 17, 2011 | 12:38 PM
1994formy's Avatar
I took em both out the top... Just had to take out #3 and 5 plugs, lift it up and forward a little, then tilt the back/flange down where the plugs were and pull it out. Just had to remove the dipstick tube for the passenger side to lift out the top.
Old May 17, 2011 | 01:46 PM
TheBlur's Avatar
I caught hell with mine as my 96 car had four catts. I pulled all the plugs, dipstick, starter, steering linkage, broke the Temp sensor . Used a sawzaw, wrenches with extensions, etc. Was HELL . But all was necessary as I installed Long tubes and new plugs/wires after.
Took two days, a big hammer, a sawzaw and an act of god. Recommend not buying headers with the 02 hook-ups but I thought I needed them for emissions. Boy was I wrong .
Old May 17, 2011 | 04:22 PM
Your 96 had four cats? Why? Where?
You need the O2 sensors on the headers to allow the PCM to control the A/F ratio in closed loop. If you delete the O2 sensors, you need an open loop tune.
And, finally.... Sawzall (copyright by Milwaukee tools)
Old May 17, 2011 | 09:09 PM
TheBlur's Avatar
Wish I had pics but one was in the driver side tucked up inside by the manifold, other in the normal location by the passenger side exhaust....Maybe 2 ? Hell, I don't remember all I know is it SUCKED . Then installing with EGR fittings on the [EDIT] headers that I didn't have to have then installing the egr hose to header gasket using a long hemo stat :mad[EDIT]
EGR Pacesetter headers for sale. Tylenol, midol, and a 5th of hooch comes with purchase.
Old May 17, 2011 | 09:18 PM
94QuasarZ's Avatar
Wish I had pics but one was in the driver side tucked up inside by the manifold, other in the normal location by the passenger side exhaust....Maybe 2 ? Hell, I don't remember all I know is it SUCKED . Then installing with EGR fittings on the [EDIT] headers that I didn't have to have then installing the egr hose to header gasket using a long hemo stat ......[EDIT]
Old May 17, 2011 | 10:08 PM
Knock off testing/overriding the language filter, or your posts will be deleted.
Old May 17, 2011 | 10:33 PM
TheBlur's Avatar
Sorry about that, won't happen again. Been out in the field for a month......sucks.....
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
