Best way to remove exhaust manifolds
Old Apr 4, 2003 | 01:49 PM
  #16
flyboydave's Avatar
Originally posted by ACA Performance
Rust = Iron Oxide
just use a good penetrating lubricant. not wd40. we put the stuff on my bolts a few times a day and none broke off in the head, but every bolt broke on the y-pipe
In layman's terms, yes. Chemically, that is not exactly true. Iron+oxygen= Iron Oxide. Rust is Iron Oxide + Water, which is technically called hydrated iron (III) oxide or Fe203xH20. Heating does two things - cooks out all the water, and turns the hydrated iron oxide which has bonded the nut and stud back into iron oxide, which has much lower shear strength. Also, if done correctly, the heat expands the nut more than the stud, which gives even more clearance. Sure, penetrating lube usually works, but you have to wait. I hate to wait. If you don't want to wait several hours, or a day, use a torch. The nut will come off right then.
Old Apr 4, 2003 | 04:45 PM
  #17
DarkHorse's Avatar
I think they were speaking more about the y-pipe bolts not the actual manifold bolts when heating. At least I was, I'd never even attempt to get a torch in that tight spot and I'm pretty damn good with a torch.
Old Apr 4, 2003 | 05:12 PM
  #18
flyboydave's Avatar
Right, I was speaking very generally. It would be a little tricky to get heat onto the stock manifold collector bolts without burning other things. The y-pipe would be pretty easy, but if those are that frozen, I just let them break off and replace them with stainless bolts anyways.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
markaubuchon
Jan 14, 2015 01:48 AM
spearous
Jan 12, 2015 11:03 AM
