Best Way To Remove Balancer Without Impact Gun When You Have This Style
Old Sep 10, 2006 | 03:06 PM
playa7970's Avatar
ANY IDEAS THANKS FOR THE HELP
Old Sep 10, 2006 | 03:08 PM
Dave89IROC's Avatar
Re: Best Way To Remove Balancer Without Impact Gun When You Have This Style
Unbolt, Use Puller In The Other 3 Bolt Holes
Old Sep 10, 2006 | 03:22 PM
playa7970's Avatar
i try to remove the three 3/8 bolts but how can i keep the balancer from spinning all the time?
Old Sep 10, 2006 | 03:37 PM
Dave89IROC's Avatar
put the bolts in the 3 empty holes and holde it with a screwdriver/prybar
Old Sep 10, 2006 | 03:42 PM
Loadre's Avatar
Stick a big screwdriver on the back of the flywheel.
Old Sep 10, 2006 | 04:26 PM
playa7970's Avatar
damn thanks i didnt even think of that thanks
Old Sep 10, 2006 | 04:48 PM
marshall93z's Avatar
The easiest way I have EVER done it was, take the bolt out, take a propane torch and heat the part that is on the crank. Turn it around a couple times while heating it, then take a deadblow hammer and hit it from the backside with the motor upside down, then turn it(REPEAT). Took about 3-4 minutes tops!
Old Sep 10, 2006 | 04:50 PM
sbs's Avatar
sbs
With a socket on the center bolt.
BigWil
Mar 29, 2015 12:24 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Hurin
Dec 13, 2014 07:38 PM
