Best way to pull an LT1 from an F-Body.
Old Dec 21, 2005 | 10:24 AM
  #16
bdc95ta's Avatar
Re: Best way to pull an LT1 from an F-Body.
I reasently did it out the top & I would say definitly bottom if you have a lift or a safe way of getting it up that high. Taking out the bottom you can leave a lot of crap on the engine which saves time. Taking it out the top was time consuming but not hard, with the right help.
-brandon
Old Dec 21, 2005 | 11:24 AM
  #17
Eddie Z-28's Avatar
This has sparked a new question to my mind. Should I even bother taking the engine out to do a heads/cam?
Old Dec 21, 2005 | 11:39 AM
  #18
Mean Green's Avatar
if it's just heads and cam, leave it in.
Old Dec 21, 2005 | 04:17 PM
  #19
amean94ta's Avatar
Originally Posted by camarolover20
U will have 2 install the intake with the motor in the car.
not me and thats using a reg cherry picker
Old Dec 21, 2005 | 05:07 PM
  #20
Loadre's Avatar
How to you line everything back up (after dropping it out the bottom) when it's time to go back in?
Old Dec 21, 2005 | 07:40 PM
  #21
Evil Eric's Avatar
3 bolts on each side of the k-member and the 4 on the trans cross member are all that is holding it in place, aside from the shock mounts. More than 1 person and those 'wheel creeper' things under the tires make it really easy to line up. The shock towers come into contact with the frame first when you raise the engine up into the car, once those are bolted back up its a matter of 'nudgeing' the k-member where it needs to be to line the holes up for the frame mounts.
Old Dec 21, 2005 | 08:14 PM
  #22
FastZinTennessee's Avatar
I must be the only one who'd rather drop the motor out to do heads/cam than bruise/cut myself up trying to work in the engine bay.
Old Dec 21, 2005 | 09:37 PM
  #23
rskrause's Avatar
Moderator
Me to, I'd pull that sucker.
Rich
Old Dec 21, 2005 | 09:38 PM
  #24
bdc95ta's Avatar
if you have practice w/ pulling the engine I don't think it's a bad idea either. If it's your 1st time, leave it in!
-b
Old Dec 21, 2005 | 09:43 PM
  #25
joshp007's Avatar
Look at my sig. I pulled it from the top with tranny. Had it out in about 2 hours or less. Page 2 has the pics
Old Dec 21, 2005 | 10:47 PM
  #26
Quickss96's Avatar
I got mine out the top today it was a success. It was great. I did brake the oil snding unit though but whatever.
Old Dec 21, 2005 | 11:06 PM
  #27
T/A KID's Avatar
Just ordered a VERY nice Eagle lift for my shop last week, pulling the motor from the bottom I would think would be a lot easier, its really going to be easy now, undo everything and lift the car in the air leaving it on the ground.
Simple enough.
O, I would rather just pull the dang motor to do Heads cam, just throw it on and engine stand and it would be Very easy, JMO.
Old Dec 21, 2005 | 11:10 PM
  #28
Quickss96's Avatar
O, I would rather just pull the dang motor to do Heads cam, just throw it on and engine stand and it would be Very easy, JMO.[/QUOTE]
I agree 100% that is why i pulled my motor (but for some people it is a job they dont want to even get close to.) Which i understand completely
Gtpguy
Jan 26, 2015 04:50 PM
formula218
Dec 2, 2014 04:27 PM
Chris 96 WS6
33
Sep 3, 2002 09:48 PM
CamaroRSguy
Aug 19, 2002 01:52 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
