Best way to clean rust off cylinder walls?
Old Oct 25, 2003 | 02:02 PM
magnumv8's Avatar
I have had my heads off much longer than I planned and now there is a little rust in some of the cylinders. Doesnt look too bad, but I need to clean it before I put the heads back on. Should I just try some WD-40 on a rag or is there something else? Also what should I use to clean the carbon and such that is on top of the pistons? Thanks
Old Oct 25, 2003 | 02:03 PM
TreySpeed's Avatar
On permanent vacation
carbon isn't a big deal. the rust is. if its surface rust- WD40 and a rag should do it
Old Oct 25, 2003 | 02:30 PM
magnumv8's Avatar
OK, I found the name of the carbon cleaner... Berryman B-12 chemtool. Can I get this at Autozone, Oreilys, or Advance?
Old Oct 25, 2003 | 02:37 PM
MadMaxz28's Avatar
yes ive seen berrymans at salvo and autozone prolly at advance too. but if you have a napa close id go for "seafoam" basicly the same thing but i think its better
Old Oct 25, 2003 | 05:40 PM
Pro/Street SS's Avatar
Cool
Do not turn the engine over you don't want the rust to catch a ring! If you see any rust use a Scotchbright pad to clean, Also clean the cylinder dry, if you use any type of lube like WD 40 the particles can wick into the top ring land.... Wipe out the cylinders with a clean lint free rag then use air at a low pressure, then just wipe ( Very Little ) some 30 weight oil in the clyinder so you do not have a dry start condition
As far as carbon, if it is slight, just leave it there, if it is more then slight, leave it there also, after the engine is running, use the Sea Foam method to take care of the top end carbon clean
John
Gator Transmission
BLK1997Z28
May 2, 2015 01:26 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
91 Redd Sledd
Aug 3, 2002 11:50 AM
