Best way to bleed the brake system???
Old Oct 13, 2003 | 11:51 PM
Z_Maniac's Avatar
I'm going to try and bleed my brakes to see if it'll help in my braking issues. Lately, specially after the cam install I would come into a stop and try relentlessly to get the car to stop but would not. It will roll until I press the brake pedal with both my feet and still it wouldnt just completely stop!!! If I needed to panic stop I'm afraid to say there is no way that I can get this car to do it!!!
So, I'm just wondering if there's any special way of bleeding our braking systems as I could not find any write ups on this subject. I thought about buying a "one man bleeder kit" but wasnt sure how good and effective those are.
Old Oct 14, 2003 | 12:25 AM
predator's Avatar
http://web.camaross.com/forums/showt...brake+bleeding
here is a good link for ya
Old Oct 14, 2003 | 07:59 AM
BlownF1's Avatar
Pick up a set of speed-bleeders from Pep Boys and install one at each corner...makes life very easy!
Old Oct 14, 2003 | 08:00 AM
BlownF1's Avatar
Ohh, and if it started after the cam install...isn't it more likely vacuum related than air in the brake lines? I think your only option at that point is an additional vacuum pump? Might be worth seeing what other folks with your same cam are finding...
Old Oct 14, 2003 | 08:06 AM
Hyperspeed97z28's Avatar
How much do they run at pep-boys and what size do we have to get for our cars?
Old Oct 14, 2003 | 08:40 AM
BlownF1's Avatar
I bought them about 6-9 months ago and I think they were $10/pair. I don't recall the size, but they had a book there with them listed by application. I saved the package at home if you can't find it easily.
I then took some clear tubing (Home Depot) and a Gatorade bottle with an under-sized hole drilled in the cap, and shoved the tube in it. All you have to do is slip the tube on the bleeder, open it slightly with a wrench, press the brakes a few times and move to the next corner. I didn't even jack the car up last time.
Rod Bender
Nov 7, 2023 02:30 PM
CheckOutMyRoost
May 31, 2015 10:40 AM
May 1, 2015 01:14 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
