Best valve covers for lt1
Old Feb 27, 2007 | 10:43 AM
  #16
KGRESOCK's Avatar
Originally Posted by Eric@Victory Racing
Is that Jason Gibbs car?
Old Feb 27, 2007 | 08:40 PM
  #17
cdb95z28's Avatar
Here`s my engine when I had some B&B Fabrication covers on it w/ a Vortech polished elbow. Those covers are the same as what Lingenfelter used to sell in their catalog. I didn`t really care for the quality of them, especially after I got my Proforms. I miss the bling, but not the upkeep
Old Feb 27, 2007 | 09:02 PM
  #18
losixfor's Avatar
$184.99
Can these be removed with the alternator on?
Old Feb 28, 2007 | 01:37 AM
  #19
blown383's Avatar
Do a search on my name and you'll come up with a thread on the install of these valve covers. Im still making a bracket to clear them. =\
-B
Old Feb 28, 2007 | 11:43 AM
  #20
Eric@Victory Racing's Avatar
Yep
Old Apr 3, 2007 | 09:11 AM
  #21
rawbutt's Avatar
has anybody with the proform valve covers had any issues with the way it lines up with the oil fill openings vs. the stock covers?
thanks!
robert
Old Apr 3, 2007 | 10:33 AM
  #22
afr lt1's Avatar
I want those proform black ones, but with perimeter bolts instead. Any pros /cons of perimeter bolt? I am thinking that my Z has a tiny bit of seepage out of the drivers side rear of the valve cover. I would assume that perimeter grips the outside better, where it counts.
Old Apr 3, 2007 | 11:17 AM
  #23
Jared 3870's Avatar
You would need different heads for the perimeter bolts. The LT1 uses the late Gen 1 centerbolt style. Unless you convert to older SBC perimeter bolt heads, your SOL.
Old Apr 3, 2007 | 11:52 AM
  #24
tapout911's Avatar
Does Canton offer a set with out the the recess for the alternator? $370 for the moroso ones.....
Old Apr 3, 2007 | 12:06 PM
  #25
12SCNDZ's Avatar
I'm using a low mount alt. bracket with the new motor, but I had these same covers on the previous engine. I had to "clearance" the back of the alternator just a little, but it wasn't a big deal.
Frank
CPT
Old Apr 3, 2007 | 12:35 PM
  #26
afr lt1's Avatar
I can use perimeter or center bolt with my AFR heads.
Old Apr 3, 2007 | 01:29 PM
  #27
Loadre's Avatar
Eric,
I'm assuming you have to ditch the PCV system with the canton covers?
Old Apr 3, 2007 | 03:09 PM
  #28
96SweetTa's Avatar
Originally Posted by Loadre
Eric,
No, why would you say that?? If you are talking about the hose from the TB to the passenger side valve cover, that can stay. The PCV stuff remains intact as far as I know.
Old Apr 3, 2007 | 04:40 PM
  #29
lt1chevelle's Avatar
is that the powermaster altanator? if so how did it fit with those valve covers? what did u guys do with that brass connector that was hanging out? iam looking to get a pair of those valve covers for my lt1
thanks
Old Apr 4, 2007 | 09:43 AM
  #30
NJLT1SS's Avatar
Here is a pic of mine. They were the ProForms with the black crinkle finish. They are now painted to match the intake and Vortech elbow.
