Best valve covers for lt1
Old Feb 24, 2007 | 08:17 PM
pat35's Avatar
Anyone have any pictures of their valve covers crome or polished that work great with 1.6 rockersfor the lt1 1995 ? Also would like to know where you got them.
Thanks!
Pat
Old Feb 24, 2007 | 11:51 PM
cdb95z28's Avatar
I have the Proform covers in black crinkle finish (#141-131), but they do make chrome(141-132) and polished aluminum(141-130). These are very nice valve covers. You can go to http://www.proformparts.com/mistore/...ER&model_id2=0 for pics/info. These vc are taller than stock and mine cleared my Comp ProMags w/ ARP studs and ARP Permalocks with no probs. They also have the superior GM designed PVC baffle. You will have to do a little grinding on the alternator. No big deal. Do a search as somebody here has pics on where to grind. I will add to be careful as to not gring too much as the area is a boss for a screw that fastens from the inside of the alternator. You wouldn`t want to grind too much and have the screw have no threads to bite on. I took my alt. apart to check it out.
You can get them at Summit Racing
Old Feb 25, 2007 | 12:02 AM
cdb95z28's Avatar
I found the post with the grinding info.
http://www.camaross.com/forums/showt...rm+valve+cover
Old Feb 25, 2007 | 12:03 AM
mdacton's Avatar
do a search there was some posted on here a while back..
I have the fabricated moroso ones, I had a few of them in that thread
I can get you some more with them off if youd like but you can't run the alt. up top
Old Feb 25, 2007 | 07:05 AM
Eric@Victory Racing's Avatar
Canton 65-206 valve covers are the way to go in my opinion.
Old Feb 25, 2007 | 08:18 AM
KGRESOCK's Avatar
How much are those covers?
Old Feb 25, 2007 | 08:24 AM
mdacton's Avatar
http://store.summitracing.com/partde...0&autoview=sku
I have these....and a madman low mount alt.
Old Feb 25, 2007 | 08:31 AM
quickSS's Avatar
Those ProForm RULE. Probably the only ones that fit over Jesel and T&D shaft rockers, (with minor grinding) accept for the leak-prone fabricated style.
some examples.
LINK
LINK
LINK
LINK
LINK
Alternator will rub as stated. One option is to get an LT4 damper (GM or ATI) and space the accessory bracket out 16mm. Any centerbolt valve cover can be used then but extra tall ones are a bear behind the cowl.
Karl
Old Feb 25, 2007 | 08:51 AM
$184.99
Old Feb 26, 2007 | 05:47 AM
pat35's Avatar
any one have any more photo's of any under the hood shots
Old Feb 26, 2007 | 08:42 PM
cdb95z28's Avatar
Pat35,
you`ve been PMd!
I cant post any pics.I`ll email them to you.
Old Feb 26, 2007 | 09:19 PM
cdb95z28's Avatar
My first pic on camaroz28.com.
Old Feb 26, 2007 | 10:33 PM
pat35's Avatar
valve covers
does anyone have any engine bay photos of a black intake with chrome or polished covers?
Thanks!
Pat
Old Feb 26, 2007 | 10:34 PM
mdacton's Avatar
I will in a week or 2
intake is a polished ceramic coating, same with headers
If I can get the VC chromed by then I will if not just a fresh polish
Old Feb 27, 2007 | 08:12 AM
