best tire pressure?
Old May 8, 2003 | 05:37 PM
sabre81's Avatar
Question best tire pressure?
i have a 94 z28 with stock rims and 255's on the back and 245's on the front. What should the tire pressure be? im most interested in gas mileage and best handling not racing.
thanks
Old May 8, 2003 | 05:39 PM
chasmanz28's Avatar
Re: best tire pressure?
thanks
i keep mine at anywhere from 32psi to 35, i have 275 40 17"s BTW
Old May 8, 2003 | 05:43 PM
sabre81's Avatar
currentley my rears are at like 43 psi. should i let some air out?
Old May 8, 2003 | 05:48 PM
chasmanz28's Avatar
i would think in the fortys are a bit high, ive herd of guys bumping up there psi if there racing are want better control, but for every day driving ide keep it were i have it JMO
Old May 8, 2003 | 11:39 PM
Laymaster's Avatar
I have all my tiresd @ 35 PSI just as the factory recommends.
Old May 8, 2003 | 11:50 PM
Rich_z28's Avatar
I run 32 for daily driving.
35 for highway
And at the track: 25 in the rears and 38 in the fronts.
IMO. 43 is way too much. Isn't max PSI on most tires like 45?
Old May 9, 2003 | 12:26 AM
Lunarson's Avatar
Usually the max's and min's are written on the sidewall of the tire's but I've always ran all of mine at around 35 psi cold.
Old May 9, 2003 | 01:18 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
normal MAXIMUM psi for our kind of tires is 44 psi... the sun and driving can change the pressure in your tires by 10 psi... i would lower those QUICK.. before you bubble or blow or something
i keep mine at 33-34 stone cold
Old May 9, 2003 | 07:57 AM
Yes. I would not go higher than 35, unless you have a heavy load in it. It will also ride a little better with less air. I usually run 2 less psi in the back as compared to the front because of the weight. So that might be 35 frt and 33 rr.
Old May 9, 2003 | 08:31 AM
ryker77's Avatar
Look on the tire.. If its says 40psi and you never use the back seat or haul heavy items them 45-48 is safe. Remember that the road temp plays a huge part in the psi of the tire. If you air the tire up in december in the cold and a few months later when the temp is higher you'll be at an usafe psi in the tire.
I own a Honda Insight and run 50psi. I loose about 5mpg when the pressure is less than 45psi. So I check it often.
Also note the reason the psi increase the MPG is that you have less rolling Resistance and less tire on the road. Which = less traction
Thats why when drag racing or for trucks muddin and rock climbing they run low tire pressure.
Old May 9, 2003 | 08:55 AM
I don't understand your logic at all. If it say max pressure is 40, then you can safely run 45-48?
Max pressure on my tires is 44psi.
The only reason you bump up pressure is when are are carrying a heavier load. What you want is the correct pressure for the load you are carrying to create the correct contact patch.
I do agree with the higher pressure causing a decreased contact patch. You don't want that-it's unsafe and wears out the middle of your tires.
RichJ
Sep 14, 2002 09:37 AM
Frank95z
Sep 10, 2002 08:30 PM
97bowtie
Aug 25, 2002 11:00 PM
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
