Best place to put MSD 6AL
Old Jan 5, 2006 | 09:08 AM
96 Z-Ragtop's Avatar
Getting ready to install a 6AL. I have a Moroso CAI and would like to mount somewhere around there. Any pics would be great
Old Jan 5, 2006 | 09:36 AM
Camarorob1997's Avatar
Re: Best place to put MSD 6AL
http://community.webshots.com/photo/...14337672KJNqKY mines there, was a easy spot to mount it.
Old Jan 5, 2006 | 10:43 AM
Hawk's Avatar
I used to have mine in that same spot. Mine crapped out though after it got wet from being in the rain, water got into the harness. Make sure you check where you mount it for possible water intrusion.
That being said, my next one will be mounted in a different location, possibly in the glovebox..............
Old Jan 5, 2006 | 12:03 PM
I had the Callaway CAI, which is the same as the Moroso. I mounted the MSD box flat on the filler panel for the CAI. but with the Firebirds, you have to move the headlight control module to fit it in. With the Camaro, that shouldn't be a problem.
Old Jan 5, 2006 | 03:47 PM
kirschman's Avatar
http://gallery8926.fotopic.net/show_...n.php?id=23663
I took off the fuse box and moved it under its own bracket. Then made a plate out of 1/4 sheet metal to fit the msd box, painted it and mounted it on top of the fuse box bracket with sheet metal scews. Works good and looks good if i do say so.
Killer94z
Jan 13, 2015 12:06 PM
thenewkid
Nov 27, 2014 09:41 AM
Z28 97'
Aug 8, 2002 07:02 PM
Desolate_Flux
Jul 23, 2002 08:24 PM
