valve train question
Old Dec 28, 2005 | 06:22 PM
Dansean1's Avatar
hey, anybody with an LT1 that is running aftermarket 1.6 roller rockers and stock valve springs have any problems with it (that is, the stock valve springs working ok?).
Old Dec 28, 2005 | 07:22 PM
OBE1 95Z28's Avatar
Re: valve train question
The stock valve spring is too close to coil bind (total height of the spring when compressed) for 1.6 RR's. I have a friend that ran the stock springs and after about 5K miles he broke 2 pushrods (***** on the end broke off). Never did find one of the *****
Old Dec 28, 2005 | 08:20 PM
RamAir95TA's Avatar
Some people will tell you that they are running 1.6 rockers with no problem, while the vast majority of people (including myself) will tell you that it is a bad idea, and not worth the risk. At least upgrade to the LT4 springs for as cheap as they are.
Old Dec 28, 2005 | 09:10 PM
1racerdude's Avatar
LT4 springs,retainers and keepers. If ya don't ya liable to break a stock retainer and drop a valve. Cost me a complete engine-- block,2 heads,etc.
Old Jan 3, 2006 | 11:38 PM
Dansean1's Avatar
Whats the max lift on a stock LT1 valve spring?
What exactly is coil bind? I should think throw on some 1.6's would not hurt.
Daniel
Old Jan 4, 2006 | 12:30 PM
OBE1 95Z28's Avatar
Coil bind is a condition when you're trying to compress the spring beyond the point where all the coils of the spring are touching each other.
Old Jan 4, 2006 | 12:55 PM
limige's Avatar
lt4 stuff is like $35 or something, just upgrade them..not worth the risk
Old Jan 5, 2006 | 03:38 PM
TransAm396's Avatar
i ran 1.6 rockers on my stock springed LT1(my 93) and it ran beautiful....and i beat the **** out of it on a daily basis. Also i ran a 13.4 at 106 with just rockers and a catback with a hollowed cat.So..i guesss its just luck(just like with anything else)
Old Jan 5, 2006 | 04:16 PM
bowtiethunder's Avatar
If your engine has alot of miles I would change the springs. I put 1.6 pro mags and LT4 springs on mine @165k. I couldn't believe the difference. Besides a stiffer spring will improve power because it closes the valve quicker(don't go excessively stiff though).
AdsoYo
May 2, 2018 03:21 AM
oldschool
Feb 9, 2016 09:21 PM
mark0006
Feb 3, 2015 05:12 PM
Jazsun
Dec 29, 2014 12:14 PM
