Best place to put the cut-out?
Old Dec 30, 2003 | 11:13 PM
jasons93z's Avatar
As stated above, i want as low as possible noise inside the car. Also, tomorrow im putting on the cut-out and the moroso CAI. How much HP do you think its worth. I cant wait til i install the slp headers and the 1.7rrs. Then i will have plenty
Old Dec 30, 2003 | 11:18 PM
FacelessZ's Avatar
Mine is right where my 3" cat-back begins, right after where the S pipe used to be before I did my LT install. It was installed when I still had a cat and sat right behind it and it seems to keep the resonance in the back of the car...
Old Dec 31, 2003 | 12:22 AM
MarkyMark's Avatar
Go
I have my cutout right before the rear axle.......it sounds really good and isnt too loud inside the car. As far as Hp goes I dont know maybe 20 or so........when I installed my cutout I didn't really feel much SOTP, but it does feel a little stronger up top.
________
VAPORIZER WIKI
Old Dec 31, 2003 | 12:48 AM
TaylnStorm's Avatar
With a cutout it's going to be impossible to have no noise AND vibration in the car unless it's capped. I have mine right before the rear axle.
Old Dec 31, 2003 | 12:55 AM
Antz97ZNJ's Avatar
mine was right after the rear axle also
Old Dec 31, 2003 | 01:03 AM
fastcamz28's Avatar
If performance was the single criterion (interior noise not an issue), wouldn't placement right after the Y pipe and before the cat conv (or off-road pipe) be the prime location? If not, why not?
Thanks!
Old Dec 31, 2003 | 01:09 AM
TaylnStorm's Avatar
Don't quote me, but I think you'll lose torque but gain HP as if at the rear you would gain a little of each. That's just some stuff I heard, don't know if it's true or not.
Old Dec 31, 2003 | 01:28 AM
97SS0594's Avatar
on th pass side of the car theres a lil notch just bere the axle the cut out tucks up nice in there.
cut out=loud no way around it
Old Dec 31, 2003 | 06:24 AM
12SCNDZ's Avatar
Mine is in my off-road pipe...Very easy to get to, because mine is manual (not electric).
Frank
Old Dec 31, 2003 | 07:58 AM
LameRandomName's Avatar
It probably wouldn't be too hard to make a short length of pipe meant to replace the cap on the cutout and vent the exhaust out the side of the car ahead of the rear wheel.
It would still be loud outside the car, but it would drastically reduce the noise inside.
You could probably use a short piece of flex pipe if you wanted to go really cheap.
DirtyDaveW
Dec 1, 2016 05:37 PM
meissen
Jun 1, 2015 07:59 AM
Chet1185
Feb 4, 2015 09:51 PM
Z28 97'
Aug 8, 2002 07:02 PM
Desolate_Flux
Jul 23, 2002 08:24 PM
