best non synthetic oil, help ASAP please
Re: best non synthetic oil, help ASAP please
Originally Posted by I burn rice too
If this was after you had broken in the engine with conventional, how many miles did you put on the engine before changing to synthetic? Your engine is still breaking in and will be for awhile. This could be why you saw metal on the plug. I don't see a synthetic causing excessive wear over the conventional. If that was the case, then we would use synthetic for break in. Try another one of the synthetic brands brands listed and see how that works. I'm guessing it's still breaking in.
But now I'm having second thoughts about the pennzoil since you guys are saying it's not the best choice. Furthermore I don't want my motor to look like this in a while...
http://web.camaross.com/forums/showt...light=dirtiest
My only comment about Pennzoil is that on my old '92 Ranger, I have run Pennzoil 10W-30 and Purolator filters exclusively for 358,000 miles and have never been into the engine yet. Three water pumps, three clutches and two transmissions, but the motor keeps on running, it even has the original timing chain. I am kind of **** about the oil changes, I never go past 3,000 miles.
Chris
Chris
Noct
Jul 14, 2015 01:18 AM
