best non synthetic oil, help ASAP please
Old Aug 6, 2005 | 05:42 PM
JP2005's Avatar
i am about to get the t/a running again and was wondering what would be the best non synthetic oil to run?
any ideas...anyone
Old Aug 6, 2005 | 05:53 PM
2000GTP's Avatar
Re: best non synthetic oil, help ASAP please
Pennzoil, Valvoline, and non-syn. Mobil are three of my favorites. I use Valvoline synthetic blend (mixture of regular and syn.) in my grand prix and I used to use Pennzoil in my Camaro but now I switched over to Mobil One syn.
Old Aug 6, 2005 | 06:05 PM
UltraZLS1's Avatar
I noticed an increase in oil pressure at higher engine operating temperatures after switching to castrol gtx.
Old Aug 6, 2005 | 06:49 PM
Silver's Avatar
Havoline, Pennzoil and Mobile 1 have usually been the best. Valvoline has historically been one of the worst oils in tests.
If you change your oil every 3-5k miles or so you really don't have much to worry about unless you're going for extremely high mileage. The things that seperate most oils of the same class usually only become a factor if you run the oil for long durations.
www.bobistheoilguy.com is the place to go to learn about oils. Otherwise, you're gonna be wading through a sea of worthless opinions. On that site, it's more like a small pond of worthless opinions with a good bit of facts.
Old Aug 6, 2005 | 10:10 PM
Schweet97Z's Avatar
castrol gtx
Old Aug 7, 2005 | 12:30 AM
BigJustinZ28's Avatar
castrol gtx , my 192k mile 84 z28 still runs like a top . Been feeding her castrol gtx since I got her over 6 years ago.
Old Aug 7, 2005 | 01:48 AM
SoloExceptional's Avatar
I did notice higher oil pressure when running Castrol GTX as well, I bought that 0w-30 stuff
Old Aug 7, 2005 | 08:44 AM
Tsar's Avatar
Originally Posted by Schweet97Z
castrol gtx
Old Aug 7, 2005 | 09:36 AM
FastZinTennessee's Avatar
Castrol GTX gets my vote for conventional.
Old Aug 7, 2005 | 09:47 AM
rpm4lalo's Avatar
Castrol GTX
Old Aug 7, 2005 | 09:51 AM
BlackDog's Avatar
castrol gtx
Yes I agree hands down the best according to the reports that I've read.
Old Aug 8, 2005 | 12:24 PM
transamdude95's Avatar
Castrol GTX is the only brand of oil that has been used in my T/A.
Old Aug 8, 2005 | 01:27 PM
JohnD's Avatar
The Camaro owners manual says use anything that has the starburst symbol on it with the "for gasoline engines." All the above oils have this, also my understanding is that since Chevron and Texaco merged, their non-synthetics are one and the same and both very good.
Old Aug 8, 2005 | 02:50 PM
Jazsun's Avatar
Castrol GTX startup is the ****, it actually does protect on startup w/ the use of polarized oil molecules which stick to metal.
Old Aug 8, 2005 | 03:52 PM
ArcticFuryLT1's Avatar
castrol gtx
can't go wrong with it
