TrickFlow guys... What are you running?
Old Dec 14, 2005 | 05:39 PM
UtOhCop's Avatar
Track times wise and Dyno number wise?
Old Dec 15, 2005 | 01:33 PM
UtOhCop's Avatar
Re: TrickFlow guys... What are you running?
No one runs these heads?
Old Dec 15, 2005 | 02:43 PM
z96's Avatar
z96
I Have Them But No Track Or Dyno #s Yet. I Had Them Ported From
L/e They Flow Great Numbers
Old Dec 15, 2005 | 02:44 PM
UtOhCop's Avatar
Z,
What cam are you running with them? How does the car feel?
Old Dec 15, 2005 | 03:15 PM
T/A lt1's Avatar
I also have a pair that was ported by Lloyd Elliott. These are not the best#'s b/c it was first time out but here you go. This on unutned PCM that is super lean.
1.57 60'
7.18@98mph. 1/8th mi.
I checked the 02's out yesterday and they were in the 700mv range which is dangerously lean. They should be 900 or so but I was still running the stock 24# injectors. So I put my 36#'s in and am tuning to try get it close before I go to the dyno next month. Later Clint
Old Dec 15, 2005 | 04:21 PM
Fastbird93's Avatar
I'm sitting on a bare set right now while I "gather funds" for them to get ported by Advanced Induction among other things. They'll be going on a 355 bottom end and should see about 16-18 (hopefully) pounds of boost from a D-1SC. Preliminary run date is going to be late spring.
Old Dec 16, 2005 | 06:07 AM
z96's Avatar
z96
My Builder Would Kill Me If I Let Out About Cam Lift Is Just Shy 600 W/ 114 Lsa. My Engine Was Built Low Compression 8.5-1 I Am Saving For My D1sc Going To Run 15psi. But Car Runs Very Strong . You Will Be Very Happy With The Heads. The Only On Complaint I Have Is Two Tapped Holes On Sides Of Stock Heads Are Not On The Trick Flow Set. So I Could Not Run Along The Side Of Valve Cover Spark Plug Wire Set.
Old Dec 17, 2005 | 12:34 PM
O J's Avatar
O J
Trying to figure out a spark/fuel issue, should have some track times this spring.
My LE ported TFS flow great #s though, especially on the exhaust side.
Old Dec 17, 2005 | 04:14 PM
Camaro97USAF's Avatar
432/416 with some issues with AI ported Heads. I need to go back after I get the issues figured out to see what it really does.
Old Dec 17, 2005 | 04:21 PM
Fastbird93's Avatar
How big of a bumpstick?
Old Dec 17, 2005 | 05:15 PM
eh, 23x/24x type. It's AI's custom Job so I don't know the exact specs.
Roadie
Feb 16, 2015 10:34 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
