best mods
Old Sep 19, 2009 | 04:11 PM
1996lz1's Avatar
best mods
what kind of mods does the lt1 respond to best? no turbo nitrous,or supercharger just bolt ons... bought a 1996 z28 bonestock 1 owner earlier today and love it...
Old Sep 19, 2009 | 05:00 PM
matt14's Avatar
start with a tune up new plugs and wires change oil etc.
Theres free mods u can do.
1st mods would be catback,CAI and headers then a tune.
do a search youll find tons of info on this.
Old Sep 19, 2009 | 05:06 PM
Mikes 1994 z28's Avatar
Headers first after a tune up. Make sure you get long tubes Unless your state has emisions
the differance is night and day.
Old Sep 20, 2009 | 09:58 AM
Welcome to CamaroZ28.com. You should find a large number of helpful, knowledgable people here.
Cold air induction kit first, then cat-back exhaust, throttle body coolant bypass, 1.6X roller rockers, headers, mail order computer tune.
Then determine how far you want to go. You can approach 500HP at the flywheel with porting your stock heads, and a matching cam (and supporting mods, like larger injector and fuel pump, dyno tune, etc.).
Don't forget, all the power in the world will not help you if you can't put it on the pavement. Drivetrain will ned upgrades. You will need a higher stall converter with an A4 (is your car a manual or automatic tranny?). Higher numerical gear ratio will work wonders. Sticky tires, several critical suspension mods (tubular LCA's, LCA relocation brackets, subframe connectors, etc.).
Suggestion - why not add a "signature" with basic info about your car, like year, model, engine, trans and any major mods? You've got most of it covered in your post, but the "signature" field insures that info is in every post.
Old Sep 20, 2009 | 11:16 AM
chevy94c's Avatar
stall, gears and headers
Old Sep 23, 2009 | 10:47 AM
30th_ANNIV_Z28's Avatar
im planning on getting a top end kit from LE, would it be better to get headers first or after i install the Top end kit? and i know most of it is preference but what would you guys say is the best brand of headers?
Old Sep 23, 2009 | 08:21 PM
z275plus's Avatar
It will be a lot easier to drop the headers in with the heads off.
Old Sep 23, 2009 | 08:40 PM
'94 Bad A Z28's Avatar
Says who? Took me an hour and a half max from pulling my manifolds off to bolting my Y-Pipe to my LT's with the heads on the car.
But, if you do everything at once you'll feel it all that much more.
Old Sep 23, 2009 | 10:05 PM
bkpliskin's Avatar
You'll want to do a CAI and a catback first. Then headers. Then gears and a stall. The heads/cam package should be after you've installed all the other mods I listed. Most cams require a higher stall and gears as well as headers. You can go from 275hp to 475hp pretty easily and without ever touching your bottom end.
Old Sep 23, 2009 | 10:07 PM
bkpliskin's Avatar
and to answer the "headers" question... I'd say go with Pacesetter Coated Longtubes. I was able to get mine with a 3" ypipe all for $495 brand new, that included shipping and all the installation hardware
Old Sep 23, 2009 | 10:12 PM
KYWes's Avatar
Ok I'll probably get flamed but here goes.
Does the cat-back make that much difference? What kind of gains does one see?
I've got Mac-mids, through an orp to the stock exhaust. It sounds good. I haven't had it dynoed to see what the power is now.
Old Sep 23, 2009 | 10:24 PM
The first mods on my 94 (car was less than 3 months old) were a Callaway CAI and a Borla catback. Those two together were worth 3/10's in the 1/4-mile. That would indicate about 30HP between the two mods.
Old Sep 23, 2009 | 10:29 PM
bkpliskin's Avatar
Injuneers reply is right on with what I would figure for gains. CAI+Catback= roughly 30hp over stock. A Catback will also benefit other mods you have. I would recommend one. An electric cutout would be a nice addition as well. I plan on installing one between my y-pipe and catback.
Old Sep 23, 2009 | 11:01 PM
KYWes's Avatar
Ok, I won't be doing Borlas, too pricey. Do Flowmaster or others do as well?
I was wishing I had an electric cutout when I was cruising in Pigeon Forge last weekend at the Fall Grand Rod Run. ;-)
Old Sep 23, 2009 | 11:12 PM
bkpliskin's Avatar
you can pick up a Magnaflow catback for about $400... IMO just as good as a borla or a corsa for less than half the price
