Best Header Size and Muffler
Old Apr 28, 2004 | 02:19 PM
LNorton's Avatar
I am running a 94 Camaro LT1. It is all factory and I eintend for the engine to stay that way.
What is the best header size?
I also have to run a baffled muffler. What is the best type and brand for this application?
Old Apr 28, 2004 | 02:30 PM
Nestromo's Avatar
1 3/4 headers. If anyone tells you 1 7/8 then don't listen to them. You will make less power with the 1 3/4. As for the muffler.... I'm not sure what you want.
Old Apr 28, 2004 | 02:34 PM
LNorton's Avatar
Muffler
Well, I am looking to run IHRA Pure Stock. I figured this would be the best place to find out how to find stock horsepower.
The Rule Reads: Headers permittedwith O.E.M. type mufflers, must be baffled and/or chambered. No straight through type allowed.
Old Apr 28, 2004 | 03:40 PM
RobbyRob's Avatar
If your going to build the motor any time soon 1"3/4. If not and your going to keep it completly stock 1"5/8. I would do a cat back system. Hooker sound good . I have the SLP loud mouth. You have to hear what you like. If you install something make sure you listen to it on someone's car first.
Old Apr 28, 2004 | 04:05 PM
stereomandan's Avatar
I would recommed either MAC, SLP or AS&M headers. The MAC's have 1 5/8" primaries, and the SLP's and AS&M headers have 1 3/4" primaries.
They are all great choices.
I love my MAC's ('94-'95 style) and it's hard to beat the price you can get them from, Coated, from Jet-Hot www.jet-hot.com
The headers, coated inside and out, with the Y-pipe coated inside and out is about $560 shipped to your door.
All you need is a cat or Off Road Pipe(ORP) and it could bolt up to your stock exhaust if you want, but I would recommend a new cat-back exhaust.
My headers and catback added 30-40 ft-lbs of TQ EVERYWHERE in the RPM range. The average gain from 1800-5700 RPM was 33 ft-lbs of TQ just from the exhaust. That's through a single cat. If I removed the cat and put an ORP in there, the gains would be a few ft-lbs better.
Dan
Old Apr 28, 2004 | 04:28 PM
LNorton's Avatar
System
In this class I'm looking for long tube headers straight into a baffled muffler, dumped right behind the muffler. not crossing the two sides together or using a cat at all. this car will not be driven on teh street, but the engine has to remain stock
Old Apr 28, 2004 | 04:38 PM
Forget everything I just wrote then.
Dan
Old Apr 28, 2004 | 04:41 PM
LNorton's Avatar
header
Im still set on a Jet-Hot coated header. Just not sure about 1 5/8 or 1 3/4.
The only thing i really dont know about is the muffler. I am not used to messing with baffled mufflers in the racing industry.
Old Apr 28, 2004 | 06:02 PM
bozobuttz's Avatar
Re: Muffler
Flowmaster 40 series are a 2 chambered muffler.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
QuickSilver02
Apr 7, 2015 11:12 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
