Best Header Gaskets?
Old Apr 13, 2004 | 05:14 PM
Eddie Z-28's Avatar
Question Best Header Gaskets?
I'm going to be installing some MAC headers soon. Can someone who knows direct me to some good header gaskets? I was thinking Felpro's, or maybe just getting ones from GM. From what I know, I sould stay away from coppers. Help please!
Old Apr 13, 2004 | 05:36 PM
Steve0's Avatar
Either or will work just fine. I used Felpros. From what I've seen on the board, both are highly recommended though.
Old Apr 13, 2004 | 05:48 PM
PatriotTA's Avatar
I used Felpro 1406. I think that's the p/n, do a search. That seems to be the standard around here. Make sure you get a gasket with the hooks at either ends (Felpros do), it makes installation so easy.
Old Apr 13, 2004 | 06:24 PM
stereomandan's Avatar
Yeah, I think the Felpro 1406's are great gaskets. If you want to buy the gaskets locally, the Mr. Gasket Ultraseals are what I have on my MACs with zero leaks. ($20 at Autozone) They are very similar to the felpro design.
Dan
Old Apr 13, 2004 | 06:43 PM
med_reject's Avatar
I used GM gaskets, paper ones, i had no idea at the time that gaskets are impt.
They lasted a a month before burning and leaking.
Old Apr 13, 2004 | 06:46 PM
Mindgame's Avatar
I've always had great luck with el cheapo Mr Gasket paper header gaskets. Put them in some water, let em soak and swell. Then put them on with a little high temp rtv.
As long as the header flange doesn't look like a street in San Francisco they'll seal just fine.
-Mindgame
Old Apr 13, 2004 | 06:48 PM
PatriotTA's Avatar
-Mindgame
I don't know what a street in San Francisco looks like, but I'm guessing its not good.
Old Apr 13, 2004 | 07:47 PM
superkia8's Avatar
I think its all luck? I went with the 1406s after some researching and they bit it after about a month or two. After that I just took it to a shop and let them order what they wanted? And all turned out ok! Its been over a year so far ( knocking on wood and everything else around me right now ) !
Just my .02
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
