Best engine cleaner/degreaser?
Old Mar 7, 2004 | 07:07 PM
Jay-Roll's Avatar
I wanted to clean up the engine bay for a weekend project. What's the best overall cleaner for everything under the hood? Or what's a couple things I should use? I've heard of simple green or something, is that any good? Also where can I get it? I've also heard about using WD40 on rubber and it helps keep the shine. Does that work? Greatly appreciated. I just want something that won't be harmful to anything and will keep it looking nice. Thanks in advance.
Old Mar 7, 2004 | 07:15 PM
SBCGENII's Avatar
I used a engine degresser i bought at wallmart on all the grease stuff and i use tire shine on all the rubber and plastic. Also you can get some neverdull and polish your ac, radiator and brake lines.
Old Mar 7, 2004 | 08:08 PM
Fastbird93's Avatar
Simple green works pretty well. Spray down, scrub what's necessary, run an open hose to rinse off. Do not pressure wash and by all means don't saturate the opti. Just an open ended garden hose running water is sufficient to rinse everything off.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
