Bent 2 rods in my LT1 Stroker..WHY
Old Mar 13, 2011 | 07:46 PM
  #16
ACE1252's Avatar
Re: Bent 2 rods in my LT1 Stroker..WHY
Originally Posted by joelster
You still need new valve locks. The beehives take a 7-degree lock.
In my research, when doing mine, it was 10* +0.050 locks and 10* retainers. I'm using PAC 1518 springs, but they should be the same style as the 918.
The part numbers I got were....
Spring Retainers 10* - CCA-795-16
Valve Locks 10* +0.050 - CCA-614-16
Spring Locator Kit(seats) - CCA-4705-16
The above hardware should net you a 1.75" install height(from my understanding...mine were just a hair shorter).
Here is one of the threads I got it from....
https://www.camaroz28.com/forums/sho...ocks+retainers
The hardware will depend on the type rockers you use SA or NSA(I'm using NSA). Wouldn't hurt for others more knowledgeable to chime in....if you have SA rockers, pay attention to Nightrain66's post in the above thread(post 21).
Noer
Feb 28, 2015 11:29 AM
Roadie
Feb 16, 2015 10:34 AM
Hurin
Dec 13, 2014 07:38 PM
Bill'sWS6
Aug 5, 2002 01:00 PM
