Benifit of V6 springs on rear?
Old Jun 24, 2003 | 05:25 PM
chucks97ss's Avatar
I just ordered the HAL setup from T Byrne... Trying to decide what springs to run in the rear. I would like to drop the car an inch or 2. I was told lots of people run the V6 springs? What are the benifits from them? Will they lower the rear at all?
Chuck
Old Jun 24, 2003 | 06:23 PM
IrocManiac's Avatar
I honestly do not know an EXACT answer to your question, however, with most of the weight difference being at the front, as far as lowering the car I don't see the V6 springs making much of a difference in ride height maybe 1/2 inch...I do think the spring rates damping/rebound will probably be lower resulting in poorer handling...I don't think I'd do the V6 springs in the rear...hopefully you'll get some of the suspension guru's to help you out, but thats my opinion...
Old Jun 24, 2003 | 10:40 PM
chucks97ss's Avatar
ttt
Old Jun 24, 2003 | 10:52 PM
SCgreen94Z's Avatar
Benefit is increased weight transfer at the drags. Haven't done it, so I don't know what the result in handling would be.
Old Jun 24, 2003 | 11:00 PM
chucks97ss's Avatar
Well yeah, i can understand that when you use the springs all the way around because it'll make the nose set lower... but I won't be doing that. I'm using HAL's in the front and need something to compliment them in the rear.
Chuck
Old Jun 24, 2003 | 11:05 PM
speedmiser's Avatar
The softer v-6 springs should let the rear squat more on launch, and theoretically transfer more weight to the back. That my or may not help you out (or hurt you), depending on the rest of your setup.
You might try posing this in the drag racing section, along with the rest of your suspension mods and power output.
I imagine that if you get the hals working up front for weight transfer, then you'd want some stiffer springs in the back to help plant the tires, not softer.
grabbem88
Feb 22, 2015 11:16 AM
ModdedNerd
Dec 25, 2014 05:51 PM
thenewkid
Nov 27, 2014 09:41 AM
slothgrant
Aug 22, 2002 03:01 PM
