Bench shifting new tranny
Old May 11, 2010 | 04:15 PM
l.m.dashno's Avatar
Question Bench shifting new tranny
I just currently purchased a used t56 tranny off ebay. I just tried bench shifting it dry with no fluid to make sure all the gears were legit. It goes smoothly into all the gears but does not seem to go into reverse. Could this just be because it is dry and not in the car?
thanks id appreciate any thoughts
Old May 11, 2010 | 04:34 PM
Are you having a problem moving the shift lever to the right, to get into the "reverse" slot? There is a solenoid that blocks reverse. I think without power it blocks the lever. Try unbolting the reverse lockout solenoid:
http://www.injuneer.com/images/photo...n/T56Conns.jpg
Old May 11, 2010 | 04:45 PM
l.m.dashno's Avatar
ya that was the problem i was having. Thats what i figured becasue it shifts smoothly into all of the other gears ill try unbolting that and see what happens. Thanks i sppreciate the help
Old May 11, 2010 | 06:35 PM
Procharged94Lt1's Avatar
Nice having smart people here huh? Sounds like a probable solution to your problem.
Henson071
Sep 18, 2015 04:01 PM
canuck94z28
Aug 19, 2015 05:50 PM
Cam's maro
Aug 11, 2015 07:45 AM
wesley81
Jul 27, 2015 11:31 AM
