Belt Tensioner
Old Apr 21, 2009 | 05:26 PM
deerslayinrenek's Avatar
Belt Tensioner
do the belt tensioners for the serpentine get weak........my belt started to squeal almost all the time and the belt is only a few months old.......it seems to be worst at an idle but maybe I just cant hear it as much when the engine revs
Old Apr 21, 2009 | 05:59 PM
chevyowner02's Avatar
Yea they can get weak.
Old Apr 21, 2009 | 07:43 PM
maverickmk's Avatar
also check your alternator and make sure it's not binding up
Old Apr 21, 2009 | 11:06 PM
Are you sure you got the correct replacement belt?
Old Apr 22, 2009 | 09:44 AM
silentsprintero's Avatar
By coincidence, the last time I changed my serpentine belt the bearings went out in the tensioner after replacing the belt. They are only ~$15 IIRC.
Old Apr 22, 2009 | 06:48 PM
I used the same part number as the one I took off and that one was fine and didn't squeal, it was just rotted and coming apart....This one has been fine since I put it on in September....until the last few days....I guess I better check all the pulleys for drag.........I wouldn't expect a bearing to be going out since i ran my fastest time ever at the track Friday night and it was squealing then and before then
Old Apr 23, 2009 | 12:33 PM
Don 97 SS's Avatar
Sometime the belts can become glazed with oil, dirt and road crud. This can increase the likelihood of squealing. If you have the right sized belt and it is in good condition, try removing it and cleaning. It might make a difference.
Old Apr 24, 2009 | 05:11 AM
There is an indicator/pointer on the tensioner assembly that shows you if the belt is the correct length, or has stretched. Might want to look at that first.
Old Apr 24, 2009 | 12:18 PM
alright I'll look for that and if it's ok I'll slip it off and maybe clean it up with brake cleaner or something.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
4586
Aug 18, 2015 07:08 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
