I did a search but couldn't find the info i need. I know the stock belt works with just the a/c delete but will the stock belt also work if you have march underdrive & alt. pulleys? I'm trying to find out if some has done this with the aftermarket pulleys and if they did what size belt did they use. If you have a belt part # i'd appreciate that too. thanks
derick
derick
I have the March underdrive crank pulley but I'm using it with the stock alternator pulley. I got a new belt when I installed the pulley, it was an inch or two shorter than the stock belt, not sure of the exact size though. When I did the A/C delete pulley the same belt worked, it was a little looser with the A/C pulley but the tensioner took up the difference. I'd try your belt out with the A/C pulley, it will probably work fine. If not just take it to a parts store with you and find some thing slightly smaller.
