Belt problems
Old Jun 22, 2013 | 06:59 PM
chevyowner02's Avatar
Belt problems
I have a problem with this motor eating up the belt. It has gone through 2 in around 75-150 miles. I am thing idler pully I am going to replace it should I reeplace the whole thing or the pully it's self?
Or any other ideal on what else is going on?
Old Jun 22, 2013 | 07:13 PM
slick1hunting's Avatar
Do a good visual inspection of all the pulleys looking for flatspotting or edge wear. Spin the free moving ones and check for wobbles or rough spots. Good chance it is idler pulley. The belt can cause alot of damage when it fails so definately locate the problem. I would say its either a bad pulley or something is loose or out of alignment. Edge wear points to alignment and flat spotting points to bad pulley.
Posted from Camaroz28.com App for Android
Old Jun 22, 2013 | 07:17 PM
The belt itself can also help diagnose the problem. Look for edge wear or flat spotting on it also.
Old Jun 22, 2013 | 08:06 PM
Re: Belt problems
Okay I will take a look at it tomorrow and try all of what you have mentioned and see what I come up with.
But as for the edge ware that is where it starts it will set about 2-3 groves off the crank pulley I can put it back on and 15-20 miles it is back off 2-3 groves.
It starts to get chewed on the outside.
Old Jun 22, 2013 | 08:13 PM
Re: Belt problems
Check the crank pulley for a wobble, due to the hard rubber ring that holds the two rings of the damper together cracking.
Old Jun 23, 2013 | 08:57 AM
Re: Belt problems
I checked all the pulleys that I could turn all seemed good the A/C delete had a little back and forth play. The crank pulley was tight no flat spots on the belt only missing 2-3 groves off it where it was chewed up.
Old Jun 23, 2013 | 09:43 AM
Re: Belt problems
You have to see if the crank pulley has movement from side to side.
Old Jun 23, 2013 | 09:49 AM
Re: Belt problems
Yea it did not have any.
Old Jun 24, 2013 | 01:53 PM
SSSean's Avatar
Re: Belt problems
My tensioner went w/out warning this winter.. I don’t drive the car in the winter but start it up every few weeks.. I heard the sounded like the AC compressor struggling to spin. At 1st I thought the compressor just seized up but on further inspection I found the tensioner self-destructed and was not applying enough pressure to the belt for the compressor to turn. I ordered a brand new one from Rock for $40.. When I took the old one off it was toast and from the sediment around it appeared to be failing for a while.. I never had any issue w/ belts getting chewed up until this winter. It’s easy enough to take off and inspect. For what is worth my car has kind of low miles 85K and always garaged and it failed.
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
warmeck
Mar 22, 2015 06:43 PM
grabbem88
Feb 23, 2015 09:41 PM
1LEThumper
Jul 14, 2003 12:45 PM
