before I proceed any further with an opti swap..
Old Dec 10, 2003 | 12:21 AM
Zack's Avatar
just need to verify. I was doing the TB bypass. Coolant leaked down to the opti. I went to start it, it started, but shut right off.
Old Dec 10, 2003 | 12:29 AM
revtime's Avatar
Have you tried it since?
Give it a little time to dry out and see what happens.
It may turn out that you do need an opti but I would not jump into it just yet, give it a little time and make sure before getting into an opti swap.
Old Dec 10, 2003 | 01:18 AM
BPS's Avatar
BPS
agree wih rev time - let it dry off and try again -
opties' do not like to get wet but that are not THAT sensitive that a bit of coolant running over them woruld cause them to break - if so they would break ever time we have a heavy dew
Old Dec 10, 2003 | 01:29 AM
S8ER95Z's Avatar
It takes a bit of coolant to leak on it (like the hose spilling coolant ALL OVER IT and then you still have a chance of it not dying.
Old Dec 10, 2003 | 01:48 AM
Ace_437's Avatar
I still need to do the bypass myself, and was wondering about coolant getting on the opti. Are some rags placed under the TB enough to keep the coolant away? How much comes out?
Old Dec 10, 2003 | 07:53 AM
Put some towels or rags under the hoses. Not a lot should come out.
Zack: are you sure you plugged your MAF back in?
Old Dec 10, 2003 | 10:42 AM
Zack's Avatar
everything's been plugged in. I went to go start it up this morning, nothing. It's been since monday. I also notice I've got an SES Light on now since the incident
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
Sep 18, 2015 03:46 PM
