beehive valve springs
Hey guys,
Going to be installing so comp beehive valve srings, couple of question. Im running a cc305 with 1.6 roller rockers and was wounder what would be better as far as springs, the 26915-16 or the 26918-16? And what is the differents between the two?I noticsed that comp say to use to different retainers too, with 915 you use the 787-16 and with the 918 you use the 774-16 what is the differents between the ? Thanxs, Grant |
I think comp may have changed some of their beehive spring part numbers.
Get the 918's with 10 degree +.050" locks and retainers and the comp locators as well. Can't remember the exact differences, but I think the 918's have higher spring rates. |
Originally Posted by seawolf06
(Post 4567789)
Hey,
What is meant when the a +.50 valve lock ? |
+.050" lock
It raises the installed height by .05". |
On stock valves you almost have to run the +.050" locks.
Bret |
