Bearing Wear Normal? (pictures)
Old May 28, 2009 | 01:15 PM
65MalibuSS's Avatar
These are from my bone stock 96 Impala SS engine with 180,000 miles.
Does the wear look typical? Excessive? Better than normal?
Mostly highway miles with Mobil 1 synthetic 5W-30 every 6000-8000 miles.
I have no idea what is considered typical for this many miles.
Old May 28, 2009 | 01:59 PM
powerslide350's Avatar
I would say normal. Just based off the 15 or so engines Ive torn down. 2 peice rear seal?
Old May 28, 2009 | 02:05 PM
65MalibuSS's Avatar
Originally Posted by powerslide350
2 peice rear seal?
1 piece (1996 LT1).
Old May 28, 2009 | 04:53 PM
jsetzer's Avatar
From what I can see it looks fairly uniform across the board. Why was the motor tore down? Still had good oil pressure?
Old May 28, 2009 | 05:26 PM
65MalibuSS's Avatar
I removed the engine a few years ago to put a Grand National engine in the car.
Now I'm just cleaning and painting the LT1 to put it in an altered dragster.
You think I even need to change the bearings or should I just leave them and reassemble it?
Old May 28, 2009 | 06:43 PM
ACE1252's Avatar
Is there something going on in the middle picture?? Looks like some type of abnormal wear to me. You can see it in the lower one too.
I'm no bearing expert, so the wear may be normal...but can't say I've seen that before.
Old May 28, 2009 | 09:13 PM
dookie454's Avatar
Could be core shift from the mileage, I had a BBC from 1974 that when assembled, the right side of all main caps didnt sit flush with the block. Motor ran fine except the cam was ground down almost flat on all lobes.
DirtyDaveW
Dec 1, 2016 05:37 PM
QuickSilver02
Apr 7, 2015 11:12 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
TitoPR221
Jan 29, 2015 08:00 PM
