bearing and ring choice for N/A motor
Old Dec 29, 2003 | 05:01 PM
v7guy's Avatar
can you use the cheaper bearing for a head and cam car without spray or boost, or would one still be better of going with the moly rings and the tri metal bearings
car spins to 6200 head and cam, balanced stock rotating assembly, nothing special really
Old Dec 29, 2003 | 07:44 PM
rskrause's Avatar
Moderator
Re: bearing and ring choice for N/A motor
The work it takes to install them makes use of cheap rings and bearings illogical. Also, even a stock LT1 is a high perormance motor which would mandate decent parts. They aren't very expensive anyway, so get some good rings and bearings.
Rich Krause
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
carl.froehlich
Mar 13, 2015 12:38 AM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
