Question about switching oil
Old Dec 29, 2003 | 09:04 AM
93transam1234's Avatar
Ok so i got a case of 5w 30 syn mobil 1 oil for x-mas. I have been running 10w 30 since i got the car last year she has 95,000 miles on her
So when i do the oil change can i use the 5w 30 syn?
Should anything special be done with this change?
Old Dec 29, 2003 | 10:24 AM
Larnach's Avatar
Well I just switched it, the car is supposed to have 5w30 to begin with, especially in winter time where the thinner oil will provide more protection.
Just switch it, I have been doing it, no problems yet.
Old Dec 29, 2003 | 04:23 PM
OBE1 95Z28's Avatar
Dyno oil and synethic are fully compatible, you can switch anytime.
Old Dec 29, 2003 | 05:43 PM
joecool72's Avatar
I think the only issue you would have would be existing oil leaks. They're clogged up with conventional oil so full synthetic will leak out much quicker.
Correct me if I'm wrong here guys....
I switched from conventional to partial synthetic because I have the typical rear intake oil leak and worried about this issue, myself. So far my oil pressure has stayed higher than conventional oil and I haven't noticed any odd oil drop, either. So far so good!
Old Dec 29, 2003 | 07:19 PM
bowtieforpower's Avatar
mobil 1 is great oil. although royal purple claims to gain hp just from changing to their oil......
Old Dec 29, 2003 | 07:54 PM
Joe Bellman's Avatar
I have seen these tests done before but they never tell you what kind of oil was in the car before or how long it was in. I guess if you went from k-mart's blue light special oil that was 7,000 miles old to brand new royal purple, you probably would see a gain in horsepower. I would like to see them put brand new Mobil 1 in do a dyno run then put in royal purple.
Z28countrymama
Jan 22, 2015 02:50 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
