BBK's mids and changing sparkplugs???
Old May 4, 2007 | 11:09 AM
F.I.94z's Avatar
I have bbk headers and I am having trouble getting the plugs out of #5&7. Does anyone have a trick to do on these two? The others I have got out fairly easy but these two are killing me. Thanks in advance for the help. Buck
Old May 4, 2007 | 12:08 PM
redneck01's Avatar
when i had them..it was a matter of extensions and swivels..and reg open ended wrenches
Old May 4, 2007 | 12:09 PM
2000GTP's Avatar
Agreed, a spark plug socket and open end wrench should do the trick in the tight spots.
Old May 4, 2007 | 01:29 PM
F.I.94z's Avatar
the problem that I am running into is that I cant get the socketon then the wrench. It was the last two I tried and after an MSD opti and 6 plugs I was ready to start trowing crap. I will give it a try again. Thanks Buck
Old May 4, 2007 | 02:52 PM
2000GTP's Avatar
You may have to grind the socket down then to make it fit. I have seen special spark plug sockets for sale in Summit that are shortened as well.
Old May 4, 2007 | 03:10 PM
CrazyLT1's Avatar
Your doing those 2 from underneath the car correct?....
TitoPR221
May 26, 2015 12:20 AM
Lt4Z2897
Mar 26, 2015 03:02 PM
alphaauto
Jan 23, 2015 07:42 AM
derty
Aug 23, 2002 04:24 PM
Mike Meyers
Aug 14, 2002 01:26 PM
