BBK Throttle body
Old Mar 2, 2007 | 11:35 AM
riodealz28's Avatar
BBK Throttle body
a freand of mine is selling me a bbk throttle body for $150 but we are not shure if its the 52mm or the 58mm but what do yall think should i buy it is it worth it
Old Mar 2, 2007 | 12:35 PM
lt1 beast's Avatar
the stock tb is a 52 mm you will see minimal gains but for 150 and the bbk logo and finish you canty go wrong...and you could always have it ported
Old Mar 2, 2007 | 12:42 PM
MaxLean's Avatar
Stock is 52mm??? That's the first I've heard this one. Stock is actually 48mm. For $150 I'd definitely do it. Remember that if it's a 58mm you'll need to port the manifold out to 58mm as the stock opening is 52mm (not the TB, stock is still 48mm for that).
Scott
Old Mar 2, 2007 | 01:03 PM
2000GTP's Avatar
Scott
You are correct on the throttle body, it is a 48mm stock. As for the openings in the intake, they are actually an oddball size of 54mm. As for the original question, for a 150 bucks, I would buy it, that is a good deal. The easy way of knowing what size it is is to get a micrometer and measure the bores.
Old Mar 2, 2007 | 05:23 PM
Z95m6's Avatar
If the TB is a 58mm i'd buy it and use it. If the TB is only a 52mm i'd pass and just get a ported stocker as they're usually more reliable and trouble free.
Old Mar 7, 2007 | 02:36 AM
canuck94z28's Avatar
bbk tb
Ihad the 52mm last year but IMO it was a waste of money.I,M going back to the stock 48MM one w/ a slp air foil. I found out that the car needs atune to get the most out of the tb. I also lost bottom end torque, had to modify the cruise control linkage,the plastic cover no longer fits, the throttle spring is tighter(not a good thing in my opinion!) and related to tuning the shifts feel sluggish. Unless your doing H/C,ETC the stocker and air foil is fine.BTW i am also going to be selling this thing.
Old Mar 7, 2007 | 05:22 AM
The diameter of the bores on a stock LT1 intake is 52mm. There is a small chamfer that makes them look like they are 54mm, but they are not.
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
warmeck
May 1, 2015 11:30 AM
lt1-xjs
Jan 17, 2015 07:52 PM
