BBK TB Gaines???
Old Jun 16, 2003 | 11:49 PM
95z115's Avatar
BBK TB Gaines???
How much horsepower will I gain if I buy a BBK 52mm throttle body with the mods in my sig. Also, I hear with this TB makes your camaro sounds identical to a superchargered camaro, is this true?
Old Jun 16, 2003 | 11:58 PM
IrocManiac's Avatar
Haven't heard anything about making it sound like an sc'd camaro...as for power you may pickup 5 rwhp...I don't think you'll pickup a lot honestly...I could be wrong though.
Old Jun 17, 2003 | 12:32 AM
ZYALATER's Avatar
Little too nothing!! The money could be spent, more wisely
somewhere else. Your car looks great already, spend it on a
suspension mod.
Old Jun 17, 2003 | 03:24 AM
SVT Killer LV's Avatar
I just put a BBK 58mm TB on mine, but then again, I have heads and cam.. Although I don't see how it can hurt stock. I would just get a 58mm.. Later on you are going to want to go from 52 to 58.
BTW you have to have the intake ported to take advantage of the 58mm.
Old Jun 17, 2003 | 03:28 AM
GhostZ's Avatar
Yup...the BBK will make you sound S/C'd at idle.
Old Jun 17, 2003 | 04:15 AM
SilvercamZ28's Avatar
I am also running a 58mm BBK TB and I havent noticed that mine sounds s/c... but I did notice an increase in power especially when I ported out the MAF...
Old Jun 17, 2003 | 07:30 AM
96 TA's Avatar
I have a 58mm Holly. I dynoed 10 peak hp less vs. stock 48mm. Through the rpms tho I only lost no more then 5-6hp so nothing noticable. you'll have a better throttle reasponse with either TB's 52 or 58. I belive that with my rr's ill actually see some gains from the TB but who knows.
Old Jun 17, 2003 | 07:33 AM
GhostZ's Avatar
If I remember right www.projecttransam.com has dyno sheets of hp/tq improvements on every mod they did to the car....might want to check that as well.
truecontr3
Oct 11, 2015 09:30 AM
colts0455
Sep 22, 2015 02:03 PM
95craz28
11
Sep 12, 2015 07:47 AM
colts0455
Sep 2, 2015 12:41 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
