BBK or Holley 52mm??
Old Nov 9, 2006 | 09:01 PM
johnny3986's Avatar
Question BBK or Holley 52mm??
Looking to get a 52mm throttle body since I researched and found out that a 54mm flowed enough air to feed Injuneer's Wonder, so obviously, I don't even need that.
Anything against either one? Holley or BBK?? Appearance is a 0 outta 10 on the importance scale.
Just lemme know.
Old Nov 9, 2006 | 09:02 PM
mobleman's Avatar
take a look at the new summit throttle bodies. They seem promising, I plan on getting one this spring..
Old Nov 9, 2006 | 09:06 PM
kline454's Avatar
I have a summit 58mm very nice works well.
Old Nov 9, 2006 | 09:08 PM
reamo04's Avatar
summitracing.com also has edelbrock for around 300 if u want name brand for a cheap price
Old Nov 9, 2006 | 10:34 PM
johnny3986's Avatar
Let's pretend I was getting a good deal on a used one. Which one would you guys buy?
Holley or BBK??
Old Nov 9, 2006 | 11:01 PM
reamo04's Avatar
if its used, doesnt really matter, ive heard of both of them having some problems, but they are easily fixed
Old Nov 10, 2006 | 11:27 AM
2000GTP's Avatar
Its really going to come down to a matter of appearance. The Holley looks alot better in my opinion, but in the long run, they both do the same job.
Old Nov 10, 2006 | 02:57 PM
Severous01's Avatar
neither for quality reasons. ebay's bored stocker for me.
i can polish it up if i want it polished, i can buy a "billit" plate if i want one of those and i'm not going to spend 400 for me having to fix something brand new.
Old Nov 10, 2006 | 08:46 PM
2QUIK6's Avatar
Yep..that is rediculous that no company can make a TB right for under $400.... I had to make several mods to my Holley to make it work correctly....blades wouldn't close 100%..TPS showed 2-5% all the time...and idle air passage venturi was missing, causing the IAC to be open way too far all the time, sometimes to the max.
Old Nov 11, 2006 | 09:33 AM
Z-RATED94's Avatar
Cost me $150 to have my stocker ported to a 52mm, why buy a new one?
Old Nov 11, 2006 | 11:13 AM
Just lemme know.
What I really said :
On the engine dyno, making approx 500 flywheel HP, my 58mm TB was only open 77%, and opening it farther did not increase measured air flow. Calculating the open area, you could come to the conclusion that I could have had the same results with a 52mm TB open 100%.
Old Nov 11, 2006 | 03:17 PM
johnny3986's Avatar
lol...well, I wont be making 500 any time close, so if you found out your brute was good at 77%, a 52mm at 100%, you could conclude, would still be overkill for me since I still wouldn't be at 500hp.... unless I added some stickers.
But thanks again, Injuneer I can get a used Holley or a used BBK from my buddy's junkyard for $150, I just didn't know which was better.
That Holley is pretty though... lol
EDIT: Oh I see I put 54mm on my first post
truecontr3
Oct 11, 2015 09:30 AM
95blkss
Sep 22, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
colts0455
Sep 2, 2015 12:41 PM
colts0455
Jul 24, 2015 04:51 PM
