Battery Has Blue Foam
Old Oct 13, 2004 | 11:23 PM
BoobSter-lt1-z's Avatar
SHOULD I WORRY IF THERE IS A BLUE FOAM SUBSTANCE ON THE BATTERY POST???...IS THIS CORROSION? CAN I JUST CLEAN IT??? IS IT INDICATING A LEAK ON THE BATTERY???
Old Oct 13, 2004 | 11:51 PM
bt96ss's Avatar
Re: Battery Has Blue Foam
Go get a battery brush and a can of battery cleaner. Spray the cleaner on let sit for a minute or two then brush it off. Repeat if needed. You can get another spray coating and coat the terminal to prevent this from happening again. Make sure the terminals are tight and you still have a good body ground. Hope this helps
Old Oct 14, 2004 | 12:23 AM
The blue foam is copper sulfate, formed when the sulfuric acid in the battery vents, and the sulfur combines with the copper in the wires. Not good to leave it that way. You can remove it with a solution of baking soda mixed into a thin paste, with water. Excessive "blue" may be indicating excessive venting of the battery, due to overcharging, or a leak in the case, or around one of the terminals.
Old Oct 15, 2004 | 10:22 PM
Thanks a lot for the help guys....
Old Oct 15, 2004 | 11:11 PM
Z95m6's Avatar
my dad always told me to put a thin layer of grease on the battery posts to prevent this. I've done it and its always worked well for me.
Henson071
Dec 30, 2015 09:55 PM
Aug 24, 2015 06:41 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
