Battery drain...
Old Oct 23, 2007 | 11:08 AM
  #16
SS RRR's Avatar
Mkay... a little more testing has been completed and I believe I've found the prollem. The battery is junk.
I'd like to thank Shoebox for his outstanding webpage and would like to publicly let him know I'm ready to have his children if he so desires.
This is why:
http://shbox.com/1/rap_schematic.jpg
On the right where it states:
BOTH RELAYS WILL REMAIN ENERGIZED FOR 10 MINUTES IF DOORS ARE NOT OPENED
So.. when I was milling about prodding around I would open/shut the doors and would never keep power applied for 10 minutes. I did so and discovered after 10 minutes the draw was a mere 20MA. Take power off and reapply it would jump right back up between 80 and 100MA. I'm off to get a new battery.
Thanks to everyone for the help!
Originally Posted by BUBBA
As long as your battery is hooked up and you let it sit for long periods of time, it is going to eventually run down. The only way to deal with it is to get a battery maintainer. Either plug it in and hook to terminals, or hook it up underhood and merely plug it in when you are not driving it much.
A week shouldn't kill a battery. My other Optima was fine w/ that.
Old Oct 23, 2007 | 11:36 AM
  #17
BUBBA's Avatar
Righto: A week would probably not kill a battery, however if you just went to church and back each week, you would not drive enough to top off your battery and it would eventually drain to the point that it would not start the car.
Old Oct 23, 2007 | 12:37 PM
  #18
dangalla's Avatar
you should always wait for about 40 minutes before checking for draw to ensure the vehicle has "gone to sleep".
if you consistantly let the car sit like that a battery disconnect switch might not be a bad idea
Old Oct 23, 2007 | 05:13 PM
  #19
SS RRR's Avatar
Nah... when I go for my 'Praise the Lord" church agoin' drives they're around 70mi if not more.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
weedog
Aug 15, 2015 08:23 PM
