Battery charge affects performance?
Old Feb 4, 2004 | 05:23 PM
Detroit808's Avatar
Would a really weak battery affect my 1/4 mile time in any way? I'm afraid using my manual fan switch on high in the staging lanes is sucking too much power. Could the battery drain be negating the cooling advantage?
Old Feb 4, 2004 | 10:19 PM
Detroit808's Avatar
anyone?
Old Feb 5, 2004 | 12:33 PM
Detroit808's Avatar
up
Old Feb 5, 2004 | 04:15 PM
Detroit808's Avatar
is that a no?
Old Feb 5, 2004 | 04:16 PM
Low voltage will reduce fuel pump output and possibly coil output.
Old Feb 5, 2004 | 04:35 PM
OldSStroker's Avatar
If your alternator is working properly it'll be putting out 13.5 to about 14 volts during your run. You shouldn't be low on juice that way.
Old Feb 5, 2004 | 08:26 PM
Robs97Z28's Avatar
but if your battery is low.The alt will boost up volts and amps to recharge it. so, the alt is sucking hp off the motor in order to recharge to battery.
Old Feb 6, 2004 | 12:04 AM
Detroit808's Avatar
looks like it's time for the yellow top mod!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
silvermansteve
Mar 4, 2015 05:02 PM
97z28k&N
Jan 9, 2015 04:58 AM
