Bare block wieght?
Old Nov 1, 2004 | 09:28 PM
Eric Bazan's Avatar
Bare block wieght?
How much does a LT1 block wiegh? Just the bare block, I need to know to find out how much it will cost to ship a block.
Eric
Old Nov 1, 2004 | 09:51 PM
ftransam1's Avatar
Re: Bare block wieght?
I'm not too sure but probably a good 140-150 lbs. It took 3 people of average height and build to lift it unless we're all just very weak.
Old Nov 2, 2004 | 12:04 AM
93turbo5oh's Avatar
190lbs
Old Nov 2, 2004 | 12:26 AM
5.0THIS's Avatar
On a scale that was accurate to within .01%, a 2 bolt LT1 block weighed in at 107 pounds with main caps and main bolts
Old Nov 2, 2004 | 12:42 AM
93turbo5oh's Avatar
a stock ford 5.0 block weighs 135. the lt1 block a lot heavier.
Silvershark's Avatar
I havent weighed mine yet... Though I had my brother ubolt it from the engine stand And I carried it to my pickup bed. So it cant be too heavy. Prolly 100-150lbs. I am in construction though, so I lift 70-200lbs items all day long, so it may differ for others. It's defiantly heavy for one person.
Old Nov 2, 2004 | 12:54 AM
93turbo5oh's Avatar
heres a link i found. a 90 model 350 block weighs 163. so the LT1 is probably in that ballpark.
http://www.vorshlag.com/tech_weights.asp
Old Nov 2, 2004 | 07:27 AM
OldSStroker's Avatar
Eric
If you figure 200 lbs with packaging you can get a trucking estimate. Up to 300 lbs. it might be the same. Consider strapping it to a small wooden skid. It's easier to handle with a forkllift and will probably get better handling.
Ask the trucking company for shipping cost either to the business where it will be worked on, or to the nearest terminal where it can be picked up if it's going to a residence. Consider shlepping it to the terminal nearest you to save a one-time pickup cost. Also, if you are shipping it to a business, ask them if they have a common carrier (trucking company) they have a freight deal with. It could save you money. It may have to go "collect" (they pay), but they might accept this billing IF you send them the money at the same time you ship the block. Talk with them.
Good luck.
Old Nov 2, 2004 | 08:04 AM
rskrause's Avatar
Moderator
You need to talk to the guy who certified that scale! They are ~180lbs, more or less the same as every other iron small block Chevy. The range for iron small blocks is ~167lbs for the short deck race block to a bit over 200lbs for some of the HD Bowtie blocks. Those weights include the main caps. Aluminum gen I blocks are in the 90-100lb range.
Rich
Old Nov 2, 2004 | 05:03 PM
InsuranceGuy's Avatar
I just weighed my 93 LT1 bare block w/main caps.
163 lbs.
Emil Dusek:93 Z
Old Nov 2, 2004 | 07:36 PM
ninetythreez's Avatar
I have shipped several. The are around 200 lbs.
Boss002
Jan 20, 2016 12:17 PM
chevy94c
Sep 17, 2015 04:16 PM
ShiftyCapone
Aug 27, 2015 10:14 AM
MichiganSkip
Aug 6, 2015 09:38 AM
Boss002
Jul 9, 2015 03:33 PM
