Balancing Question
Old Jan 28, 2005 | 09:56 AM
93ZM6Tally's Avatar
Balancing Question
This is really for anyone that's put together a stroker using the GMPP 3.80 Stroke crank manufactured by Cola. It looks to me like this crank has already been through the balancing process and I'm wondering if Cola supplied the cranks to GM using the balancing spec's for the GM RA. I'm thinking that the crank may balance easier, (requiring less metal), if I go to an internally balanced setup, in other words, a neutrally balanced flywheel, rather than going external balanced, balanced with a counter weighted flywheel. Reason I'm asking is I'm in the process of buying a street twin and trying to decide to get the LT1 or the "Neutrally Balanced" version.
I'd be real interested in hearing from anyone who has used this crank, and how they had it balanced, internally or externally and how much Mallory had to be added for either method.
Thanks.
Mark.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
Jason Short
Jan 19, 2015 06:33 PM
