balancing
Old Dec 10, 2008 | 03:21 PM
red94chicken's Avatar
crank balancing?????
what is the gain from having an internally balanced crank as apposed to stock style balancing?
Old Dec 10, 2008 | 03:39 PM
seawolf06's Avatar
You have have the flywheel and clutch setup neutrally balanced and that will make changing those parts out much easier.
Old Dec 10, 2008 | 03:54 PM
not worried about the parts changing aspect.
Old Dec 10, 2008 | 10:14 PM
rskrause's Avatar
Moderator
No advantage then. In super hi-po applications internal balance my be a little easier on parts.
Rich
Old Dec 11, 2008 | 01:54 PM
hosspwr94's Avatar
in my opinion the internal revs quicker than external due to not having to "throw" weight in a circle all the time.
Internal balance parts are easier to come by.
Old Dec 11, 2008 | 02:50 PM
rskrause's Avatar
Moderator
There is just as much inertia when the weight is in the crank counterweights.
Rich
Old Dec 12, 2008 | 12:02 PM
blue 79 Z/28's Avatar
Rich
i agree, but isnt the weight on the flywheel/flexplate further out then the counterweight on the crank. that does make a difference. closer to center the better.
Old Dec 12, 2008 | 12:16 PM
hosspwr94's Avatar
This has always been my understanding...
less stress on the crank this way, doesn't change horsepower but I feel it allows the engine to spin faster and easier than external weights
Internal balance uses the matching weight of the RA to offset using external weight where external balance has to counter the weight of the crank using extra weight.
most of the new cranks out there very rarely have to add heavy metal anymore to get the balancing done.
Old Dec 12, 2008 | 12:25 PM
rskrause's Avatar
Moderator
But it requires less weight.
Rich
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
