balancer bolt
Old Aug 26, 2008 | 07:45 PM
texastransam96's Avatar
balancer bolt
i was changing my opti and noticed that the main bolt holding the balancer on had came loose again.. it was loose when i first got the car, and i torqued it back down, and now it has worked its way loose again...
if it helps i have been changing some very nasty misses in the engine, and it completely dying it was getting so rough, would this cause it to work its way loose, or is there possibly something else bigger wrong with the engine??
oh and when it would run right for me it was smooth as could be all the way through the rpm range, so i dont think the engine is out of balance..
mike
Old Aug 26, 2008 | 07:46 PM
Does the bolt have the required thick washer under the bolt head? Is there any evidence that the damper hub is loose on the crank snout?
Old Aug 26, 2008 | 07:49 PM
the crank hub is tight.. i have to press it off of the hub.. i just called my buddy and he said what washer.. he never remembered there being a washer, so i think i found my problem.. i just walked outside and checked.. sure enough no freakin washer.. anyone by any chance know the part number for a new bolt and washer??
Old Aug 26, 2008 | 08:06 PM
maverickmk's Avatar
bolt 9440024
washer 10128306
Old Aug 26, 2008 | 09:09 PM
thanks for the info
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
cyteone
Feb 7, 2015 06:04 PM
