Balance question
Old May 27, 2009 | 07:57 AM
High Strung's Avatar
Balance question
Would an 94 LT1 be a internal or externally balanced engine?
Sounds dumb but I need to use a externally ballanced flywheel on my t56 swap.
The wheel that came from the donor car has ballance marks but not sure if that is just to ballance the wheel or the motor?
Old May 27, 2009 | 01:40 PM
rskrause's Avatar
Moderator
The LT1 is externally balanced at the rear as it came from the factory. The harmonic balancer (dampener) is neutral, AFAIK.
Rich
Old May 27, 2009 | 07:53 PM
MachinistOne's Avatar
Like Rich said - internal on the front, external on the rear.
These motors are balanced with the flywheel in place, but corrections should not be made by drilling on it. I am sure those are factory drill marks to set the balance on the flywheel but it's always best get the replacement part spun up to confirm that it matches the original.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
Jason Short
Jan 19, 2015 06:33 PM
