Badly over heated my 95 Z, is it ok??
Old Apr 9, 2007 | 11:58 AM
ZONES89RS's Avatar
It was rainy cold weather and i was like "no way it got that hot that fast" so i called it bluff tilll i checked it, the car ran fine but it was boiling itself apart, i filled it and limped it home, it was past 260, you guys think its ok or does it have warped heads and the works??? I cranked it the next day and it sounds fine but i wanna know how these cars handle heat, my gen 1 small blocks hardly ever crack...???
Old Apr 9, 2007 | 12:39 PM
69gto96z's Avatar
Mine has ran that hot a couple of times, and still runs just fine.
Old Apr 9, 2007 | 01:11 PM
ZONES89RS's Avatar
Cool, i will find out in a little while...
Old Apr 9, 2007 | 01:13 PM
96 mikez28's Avatar
lol, i replied to this over on LS1 tech
Old Apr 9, 2007 | 01:36 PM
transAMdriv3r's Avatar
It should be okay...just open the radiator cap and start it up to see if it overflows. If it does you have blown your head gasket. If it overheated I would clean your radiator, buy a new thermostat and radiator cap and put fresh new coolant in. make sure it bled real good, these damn reverse cooling engines are a pain to bleed.
I have had mine in the red a few times and all is well (knock on wood)
Old Apr 9, 2007 | 02:44 PM
TobyZ28's Avatar
I had mine in the red and had warped heads and a blown headgasket shortly after.
Old Apr 9, 2007 | 03:12 PM
2000GTP's Avatar
As long as you caught it right away, you should probably be fine.
Old Apr 9, 2007 | 03:22 PM
vdubois's Avatar
Check your water for oil and your oil for water.
Old Apr 9, 2007 | 03:23 PM
always faster's Avatar
Same thing for me.The next day i overheated,the car was still starting and running perfectly but...
After a couple of days it begin to smell coolant a little bit.After another couple of days it begin to make white smoke.And 3 weeks later the low coolant light pop up and my car was making a big white smog.
Result:Warped head and of course blown head gasket.
Old Apr 9, 2007 | 03:52 PM
Loony's Avatar
Mines in the shop getting new head gaskets because I did that.
Old Apr 9, 2007 | 05:46 PM
ZONES89RS's Avatar
Well its fine so far, but it is popping so i guess the opti got wet right? But it did smoke a tiny bit when i fixed it and started it up, but it was in warm up mode and quit, the PVC valve i noticed did not have a check valve, it is supposed to right???
grabbem88
20
Dec 27, 2015 07:42 PM
May 1, 2015 01:14 PM
grabbem88
Apr 16, 2015 06:57 PM
Jan 23, 2015 01:13 PM
ro2207
Dec 4, 2014 06:18 PM
