Bad WOT Misfire
Old Apr 21, 2013 | 09:35 AM
  #31
Re: Bad WOT Misfire
Originally Posted by pboxfun
Update!!!
After installing the OTVC wires and plugs my car was still missing at high RPMs. Then my car finally threw a code 36 (Hi Res Failure) and would even start. So I finally decided to replace the optispark.
"would" start or wouldn't start? Odd thing is, DTC should not prevent it from starting. On the other hand, if you had the optical sensor covered in oil, it's very likely you also had DTC 16, which does shut down the engine.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
colts0455
Jul 8, 2015 12:21 AM
Nellsw88
May 27, 2015 10:27 PM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
